second hand pronto
Discussion in 'Home Cinema Control & Remote Controls' started by docb, Dec 22, 2004.
  1. docb
    docb
    Nov 22, 2004
    253
    Just a quick query,
    If I bought a pronto second hand would I be able to clear the memory and start again or would it be a case of having commands on there I didnt need?
    Mark
  2. jonnyv
    jonnyv
    Mar 31, 2002
    2,282
    48
    +52
    you can reset the remote to as it would be if you bought it new
  3. docb
    docb
    Nov 22, 2004
    253
    thanks jonnyv
