Secam and PAL
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by leftfield27, Jul 31, 2005.
  1. leftfield27
    leftfield27
    Hello!
    I'm moving to France next week, and my analogue video8 camcorder has just broken. I need to transfer the tapes to DVD (probably using a DVD recorder) and my parents in law have a French Secam video8 camcorder. Will this play my PAL tape, (I know that my VHS VCR plays secam tapes perfectly but in black and white!!)
    thanks, Duncan
  2. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,264
    Manchester
    +756
    It plays it in monchrome because the crucial difference between PAL and SECAM is the method of transmission of chroma information on the colour subcarrier.
    Get the model number of the French machine and you should then be able to check whether or not it is PAL compatible - many are.
    Chris Muriel, Manchester.
