Searching for a Mitsubishi VCR code
Discussion in 'Home Cinema Control & Remote Controls' started by GreenBars, Nov 5, 2004.
  1. GreenBars
    GreenBars
    Oct 29, 2004
    631
    Hertfordshire
    +23
    Can anyone help me please?
    With my new TV (Sony KD28DX50U) I received a remote control (RM933), which should be able to control other manufacturer's VCRs & DVD players. Unfortunately, no code was supplied which could control my Mitsubishi VCR (HS-561V). A :lease: call to Sony Technical Support resulted in me being recommended to contact Mitsubishi - I don't think they still sell consumer electronics in the UK, which makes them difficult to contact!
    Is there anyone out there who knows of a code which will do the trick?
  2. vizslaraner
    vizslaraner
    Dec 13, 2003
    487
    Hereford
    RE. the RM933.
    If you're talking about an internal code database; it doesn't have your VCR listed; it's not a learning remote; there's nowt to be done.
    If it is a learning remote, just teach it you VCR codes.
    If you no longer have the VCR remote try here - http://www.remotesreplaced.co.uk/makes/mitsubishi.htm
  3. simon1
    simon1
    Jul 7, 2001
    918
    28
    Teesside
    +58
    I'm afraid there simply isn't a pre-programmed code on the Sony remote to operate your Mitsubishi.
    Sony didn't include one, as Mitsubishi hasn't made a vcr in years.
  4. GreenBars
    GreenBars
    Oct 29, 2004
    631
    Hertfordshire
    +23
    I decided to go back to the manual and take another look at the codes listed against various manufacturers. The codes were between 301 and 361 and I noticed that the following codes were not shown: 346, 347 & 356. I entered 346 into the remote and lo and behold, I can now control my Mitsubishi VCR with my Sony remote! One for others to try out maybe.
