Searching for a hidden screen
Discussion in 'Projectors, Screens & Video Processors' started by Scott 2802, Sep 18, 2007.
  1. Scott 2802
    Scott 2802
    Sep 15, 2006
    25
    4
    Ballymena
    I am looking to find a screen that is pulled down and can easily be push back inside so that it can hang in are living room and not look like there is anything there - as the wife no longer wants a TV in the room and i suggested the idea of a small hidden projector and puull down screen - can anyone help
    thanks in advance
  2. ijd
    ijd
    May 20, 2005
    2,172
    63
    +126
    why not get rid of the wife, it would be much easier and you can have any size tv and a screen and not have to hide anything:thumbsup:
  3. Scott 2802
    Scott 2802
    Sep 15, 2006
    25
    4
    Ballymena
    Thanks really helpful
  4. ijd
    ijd
    May 20, 2005
    2,172
    63
    +126
    seriously, the only real easy solution is to put it behind a pelmit, although i have seen a white screen painted on the wall concealed by a picture that slides horizontally when the screen is required.
  5. Scott 2802
    Scott 2802
    Sep 15, 2006
    25
    4
    Ballymena
    Thanks lol - sorry didnt mean to be sharp there - just after another hard day in work and come home to the sound of need to remove my tv system form the living room as it doesnt look appealing - " yeah to you"
  6. ijd
    ijd
    May 20, 2005
    2,172
    63
    +126
    been there, wife constantly tells me it is a living room and not a cinema, I just have to prove her wrong:D
  7. Scott 2802
    Scott 2802
    Sep 15, 2006
    25
    4
    Ballymena
    thats the thing people dont understand its as much a hobby to me as - ironing and cooking is too you - oh god i hope she doesnt read this forumn lol
  8. ijd
    ijd
    May 20, 2005
    2,172
    63
    +126
    love it :rotfl::rotfl::rotfl::rotfl:
  9. ColdKilla
    ColdKilla
    Jun 21, 2005
    727
    +19
  10. dbs2
    dbs2
    Jun 28, 2006
    1,596
    Sunny Norfolk - uk
    +196
    Screen hidden in a pelmet is certainly the cheapest option, as for the projector, have a look on this thread by Andy, he has a great hidden screen and a drop down hidden projector, i'm sure he will be more than willing to give you some advice or help...... Deano
  11. Jonstone
    Jonstone
    Feb 12, 2006
    4,160
    Prestatyn
    +545
    Have you considered any other options?
    You can get tv's that look like mirrors when they are off such as this one
    Or there are firms that can do a tv mirror to fit any screen such as this one.
    There are also a few examples on the forums of people who have hidden their pj screen in the space between the ceiling and the floor above
  12. Movieman
    Movieman
    Jul 4, 2004
    553
    Wirral
    +21
  13. Epoman
    Epoman
    Jan 3, 2002
    3,128
    71
    On my PC
    +85
    This is what I have done. This leaves a 3cm slot from which the screen drops. It is virtually invisible until I want the screen to come down. VERY wife friendly and certainly worth the effort. I'll post a pic if you like, though it's still very much a work in progress.
  14. Scott 2802
    Scott 2802
    Sep 15, 2006
    25
    4
    Ballymena
    that would be great thanks for the help - pics to help explain would be a great help and were you bought the equipment from
    thanks
  15. Epoman
    Epoman
    Jan 3, 2002
    3,128
    71
    On my PC
    +85
    You can see a couple of pics here:
    http://www.avforums.com/forums/showthread.php?t=465286&highlight=epomans+extension
    The install has moved on since then but I don't have access to my more recent pics at the moment. I'll see if I can take some more at the weekend.
    I was lucky that the joists in my roof void ran the in the right direction. I just cut the plasterboard ceiling away (it's a new build extension), attached the projector screen to the joist, adjusted the screen drop and then had the ceiling replastered, leaving the gap for the screen to fall through.
    It’s far simpler than it all sounds. The hardest bit was adjusting the screen drop which was a bit fiddly.
    You may find it easier to access the void from the floor above which will involve lifting the floorboards.
    You really don't need anything special by way of equipment - any bog standard electric screen will do.
    Just give some thought to how you want to lower the screen. If you want it to come down when your projector is turned on then you will need to run the necessary cabling from your projector to the screen for a 12v relay. I preferred to control the screen with a remote so I have placed the remote sensor which you can just see in one of the pics.
