Seamless layer change on superbit DVDs
Discussion in 'Movie Forum' started by cybersoga, Feb 18, 2003.
  1. cybersoga
    cybersoga
    Apr 7, 2002
    1,630
    48
    UK
    +25
    How come Superbit DVD's have a seamless layer change (on my Sony DVD player)? Why don't all DVD's do that?
  2. Branxx
    Branxx
    Nov 1, 2000
    810
    London, UK
    I think the VOB files on this DVD's are carefully constructed so that VOB file change coincides with the layer change. AS the player would generally pre-fetch the next VOB file before the previous has completely finished, the layer change appears seamless.
  3. dts_boy
    dts_boy
    Nov 26, 2001
    2,615
    Manchester suburbs...
    +178
    next question - why can't they do this on all DVDS:mad:
  4. DarthChris
    DarthChris
    the layer change on star wars II atoc
    both times ive watched the dvd ive stopped the film half way through for one reason or another, so this may not be correct,
    but is the layer change by the asteroid fields one of the longest pauses there is? on most/all my films you dont even notice the transition, but on aotc its a big PAUSE
  5. Adam Barratt
    Adam Barratt
    Aug 9, 2000
    170
    16
    New Zealand
    Superbit titles have seamless layer breaks because they don't comply with official DVD specifications, which call for non-seamless layer changes (a forced buffer memory dump at the layer change).
    Other discs comply with this requirement, and therefore have visible layer changes.
    Adam
  6. James45
    James45
    Sep 21, 2002
    2,844
    59
    Taking Care of Business
    and why is that required? layer changes annoy everyone but the denon owners. tbh learning this has made the inflated superbit prices seem much more reasonable.
  7. cybersoga
    cybersoga
    Apr 7, 2002
    1,630
    48
    UK
    +25
    Why don't they change the official DVD spec? Is there anyone we can write to who would have any influence?
