Se7en... R1 or R2 " Disc set?
Discussion in 'Movie Forum' started by Len, Mar 1, 2001.
  1. Len
    Len
    Any info on the region 2... I have the old region 2 disc... was thinking of getting the 2 disc R1 version but see that this is also available now on R2. Is it the same? Is the transfer as good? Anyone got it?
  2. bradavon
    bradavon
    From what I can gather it is the same, almost the R1 comes in a VERY nice case which depicts John Does life.
    The R2 comes in a rubbish plastic case, which is why I a going for the R1.
  3. desade
    desade
    Ah yes, plastic or carboard again?
    I love carboard cases as I have previously said and if anyone still thinks plastic is superior then check out how cheap and nasty the r2 seven looks compared to the effort that has gone into the r1.
    Remeber that after a while the plastic case will also cause the sleeve to warp!
  4. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    I don't know about the rest of you but I bought R1 version beacuse it has DTS ES (discrete and matix) on the disc. Presentation is stunning on R1, R2 looks crap in comparison.
  5. Len
    Len
    That settles it then R1 it is. When play get it back in stock.
  6. Guest
    I have the r1 version which is superb
    also whilst in hmv earlier this week i checked the r2 version and couldnt see any mention of a dts soundtrack!
  7. bradavon
    bradavon
    I'm not surprised you can't see it. The DVD is made by Entertaiment in Video after all.
    You have to look in the booklet to see it does have DTS ES as well.
