sdv1300 upgrade
Discussion in 'Projectors, Screens & Video Processors' started by mira, Jan 4, 2005.
  1. mira
    mira
    can anyone help :lease: need to find if there is an sotfware upgrade for my seleco sdv 1300 dlp pj or any info how to adjust keystone or where it was actually made if anyone can help on any info it would be much welcomed because cannot find much info anywhere on pj :(
  2. AD Roser
    AD Roser
    Aug 23, 2002
    280
    East Sussex
    +17
    Mira,
    Oh boy this is a tough one, I can't remember the sequence for the keystone adjustment, if memory serves you have a heck of a lot of lens shift on this unit, have you maxed out on this adjustment? I will have a chat with the factory to see if there ia a on line manual somewhere, I'm afraid there are no further software updates for this unit as it has been out of production for about 4 years now.
    Regards
    Alan Roser
    SIM2 UK Ltd
  3. mira
    mira
    thanks for your reply Alan i think it's maxed out can't get the egdes straight my software is still origional does not have 16/9 on pal/ secan only on ntsc my manual says there is an upgrade somewhere my version is 4.02 software thanks again
