SDI SKY+ & Capture software?
Discussion in 'Sky Digital TV Forum' started by Bacon2002, Jan 9, 2005.
  1. Bacon2002
    Bacon2002
    I have a Sky+ box with twin SDI feeds, one of the feeds goes to a PC with an SDI capture card.
    Problem I have is what capture software to use. Either the software produces jerky pictures or it records fine but lacks the ability to adjust the picture quality (Colour etc).
    Has anyone else resolved this issue or is there a way of adjusting the picture quality through the drivers or a utility or app?
    Dscale records fine but the files are to big.
    Many thanks,
    David
