sdi is cropping my picture!
Discussion in 'Projectors, Screens & Video Processors' started by popeye, May 7, 2003.
  1. popeye
    popeye
    Feb 12, 2002
    779
    19
    Leeds
    I'm not sure where to post this question, so appologies if it needs moving!
    I'm in the process of having my Sim 2 (Seleco) SDG700 L6 CRT projector installed with Chris Frost. I'm using a Centerstage CS-2 video processor with an sdi input board, together with a Panasonic RP62 sdi dvd player. Upon setting up the projector Chris noticed that approximately 5% of the picture at the bottom of the image had been cropped off and was in fact missing.
    We switched to my Sony 7700 dvd player , which was hooked up to the CS-2 with a component video cable and the missing section of the image appeared.
    I'm running the projector at 720P & WXGA on a 16X9 Stewart screen
    Has anyone else experienced this problem when using an sdi source. Is there an explanation as to what's happening?
    Any ideas!!!
    popeye:confused:
  2. Jeff
    Jeff
    Jul 13, 2000
    5,489
    Basingstoke
    +256
    I would guess that its the scaler doing this, does it equally crop NTSC and PAL DVDs?
  3. popeye
    popeye
    Feb 12, 2002
    779
    19
    Leeds
    Yes it's the same for both Pal & NTSC.
    It's not a massive a problem, with a few tweaks of the scalers vertical position and size etc you wouldn't be any the wiser that there was a tiny portion of the image cropped. It's just one of those annoying problems that's more of an inconvienence.
    I must say the end result makes up for the extra tweaking.
    I'm not sure if the fault lies with the CS-2 SDI board or the SDI Panny player. It seems strange that when I use my Sony dvd player that the problem isn't there.
    popeye
