SDI current flavours?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Nic Rhodes, May 2, 2003.
  1. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    What are the current favoured SDI players? I assume they are still the chroma bug free ones (Pannasonic) rather than the pioneers. If so what does the comunity think about the 62, 82 and 91?
    sorry a little out of touch here:blush:
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,174
    +3,004
    Bee: 82 has been out of production for many months.
    62 is good but has only optical audio out.
    91 has best MPEG decoder, according to the geeks at the ISF secret squirrel web site, coupled with co-ax digital audio out.
    Gordon
  3. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    Do people have any difficulties with say the 91 and a step up transformer? I was most interested in the 82 and 91
  4. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    Hi Beekeeper,
    I believe the XP30 and XP50 have the same MPEG decoder as the RP82. They are available from www.jvb.nl as is the 91. You shouldn't have a problem with a step down transformer - I've used an imported Region 1 Panasonic player for 5 years. Hope this helps.
    Steve
  5. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    Thanks guys, put my mind to rest on the x former. Anyone know why the 91 is considered to have a better MPEG decoder?
  6. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    Hi Beekeeper,
    According to the boffins at Home Theater Hi Fi, the Panasonic RP91, RP82, CP72, XP30, XP50 and the Denon 1600 all use the same model MEI MPEG decoder. So in theory, they should have have fairly equal interlaced outputs. Check out http://www.hometheaterhifi.com/cgi-bin/shootout.cgi for their very comprehensive DVD player tests from the last 3 years.
    Steve
  7. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    Dutch
    thanks for the info, I have been re plodding through all this for the last day or so and although I can find info on the MPEG decoder (important for SDI) and deinterlacing chipsets for the US panny players, the 91 eludes me at the moment, do you know what it uses.
    He asks retiring to bed with a whisky and a pile of old US AV mags looking for that 91 review....:)
  8. nathan_silly
    nathan_silly
    No problems with using £15 step down transformers- myself, brother and a mate all use 110V machines with no problems.
    Just check that the power consumption on the DVD player is not over the transformers rating (my Sony & a Panasonic is fine, but brothers Pioneer player trips the transformer out after several hours use)
  9. Gordon @ Convergent AV
    Jul 13, 2000
    14,174
    +3,004
    Bee: The Panasonic web site actually states the mpeg decoder used I believe......Can't say I am entirely sure about diff over 62 myself. I can re-direct you to a thread about the standard interlaced outputs if you want?
    Gordon
  10. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
  11. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,152
    UK.
    +2,671
    I was looking at these models - the UK versions (RA not RP) look identical, except have a scart instead of component outputs (which I need for my pj).
    I wouldn't mind one provided it could be made multi-region. Are these hackable, or do they need to be chipped?
    Gary.
  12. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    Dutch, thanks, I knew it was there but this is the one that crashed during download! You wouldn't believe how mauch I have trawled through to find this
    Gary
    Multi region is by chips, many doing that but SDI and chips then look at JVB
    Gordon
    I think I am sorted now, did you go for the RA 82?
  13. Gordon @ Convergent AV
    Jul 13, 2000
    14,174
    +3,004
