John Dawson said:SDI is absolutely forbidden as an output on properly licenced DVD players - no manufacturer can lawfully fit it and then pass CSS encrypted data over the interface. You must use interlaced HDMI instead; in principle the digital video bits are exactly the same when using 4:2:2 interlaced video, at least on Arcam players.
John Dawson (Arcam)
Does this apply to "commercial" products?John Dawson said:SDI is absolutely forbidden as an output on properly licenced DVD players - no manufacturer can lawfully fit it and then pass CSS encrypted data over the interface. You must use interlaced HDMI instead; in principle the digital video bits are exactly the same when using 4:2:2 interlaced video, at least on Arcam players.
John Dawson (Arcam)
(this may be an SDI input), but is SDI "allowed" for commercial apps?Configurable with optional components, including:- Second DVD-R/RW drive - Serial Digital Interface (SDI) & AES/EBU audio board set
hornydragon said:Does this apply to "commercial" products?
http://www.pioneerelectronics.com/p....html?compName=PNA_V3_ProductDetailsComponent
