Quantcast
SD220 or sd220e Any differences???
F
foxes1884
Looking to buy a toshiba sd220 dvd player. i've noticed that different suppliers call it the sd220 or sd220e. Are they any differences or is it just a typing mistake?
Lux
I was under the impression that they are one and the same.
My user manual says it's SD-220EB (B for black even though it's silver) and the box says SD-220E.
I think they are the same. some retailers are just shortening it to 220, that's all.
HTH
kevenh
from a quick forum search, I can safely say ' ' ' ' They're the same thing!
Hope you're OK now.
FYI I'm pleased with my 220 ;)
