Wasn't sure whether this should be in the 'Scaler' or the 'Plasma' platform but decided that the scaler was key to the question so posted here. I have budgetted for a good HD plasma (Pan PHD8 or Pio 436) but recently I have been considering another option (Pan PWD8 + Lumagen DVI). So comaparing the PWD8 + Scaler with the PHD8 .... Price is about the same I'm interested in HD eventually but I can't see me being an early adoptor because I'm not prepared to pay high prices for limited material. The screen will be 42" and will be viewed at a distance of 12 feet or more. Current source is Sky+ and DVD, both on SCART RGB. SD I presume that the PWD8+Scaler will outperform the PHD8 - would the difference be significant? What sort of benifits would I see? HD No idea which would perform best here. The PWD8 obviously doesn't have the resolution and although it can receive a 720P HDCP signal - but I guess the panel would have to do the scaling rather than the scaler. Also I am aware that Sky HD will be transmitted on analogue aswell (at least initially). Any views as to which would look best (at 12 feet). BTW I can't go for a PHD8+Scaler because I am already pushing my budget further than planned. Thanks for any advice. Cheers, Nigel
I have gone for phd8+isf now, then saving for hd sources/scaler+re-isf next year when the bank balance has recovered. That way im future proofing, plus iirc the phd has better processing than a pwd anyway so should still look good with sd sources.
