SD on PE50 vs PV500
Discussion in 'Plasma TVs' started by e_python, Aug 11, 2005.
  1. e_python
    e_python
    Can anyone say for sure whether SD is better on Panny PE50 or PV500 - or the same?
  2. Rapid 17
    Rapid 17
    Jan 14, 2005
    837
    28
    +74
    Before i bought my PV500 i saw both screens side by side in the Panasonic shop in Brighton. The PE50 seemed a tad better with SD. However, the PV500 was the best picture i have ever seen on any television when fed HD.
    Geoff.
  3. greeny
    greeny
    I thought it was, that's why I bought a PE50
  4. bkny
    bkny
    May 11, 2005
    104
    16
    well the pe50 must be one heck of a picture, as i am constantly amazed by my picture on the pv500, watching lost the other night and was blown away. v. happy. but then i am not a v. discerning plasma owner .... ignorance is bliss
  5. Korum
    Korum
    Feb 19, 2005
    4,257
    Stockton-on-Tees
    +691
    Couldn't see any difference between the 2 on SD.They both looked fantastic with Sky.
  6. Rapid 17
    Rapid 17
    Jan 14, 2005
    837
    28
    +74
    Further to my previous reply, the PE50 i saw had been a display model for some time but the PV500 was very new. Perhaps the PE50 edged it in view of the number of hours that it had been used ? The picture quality on my own PV500 has improved considerably the more it has been used. Geoff.
  7. Artie Fufkin
    Artie Fufkin
    Aug 11, 2004
    1,600
    Aberdeenshire
    +182
    I saw the 2 side by side at a shop@panny being fed freeview through scart and the pe50 was, without any doubt, giving a smoother more natural piccy than the 500. If you're only watching SD then go for the PE50.
  8. Lionheart
    Lionheart
    Ive noticed that to Rapid...it reminds me of good quality hifi equipment that sounds average until it is run in and then it really shows you what quality kit can do
