SD-DVD better?
Discussion in 'Xbox Forums' started by ollyclaret, Dec 30, 2006.
  1. ollyclaret
    ollyclaret
    Feb 22, 2006
    13
    Does anyone know if the image quality of Standard DVDs improve when being played using the HD-DVD or would the quality be the same as when playing normal DVDs straight through the 360 (using a VGA cable, which i believe it meant to upscale anyway).
    Ta
  2. m1ket
    m1ket
    Aug 24, 2005
    3,694
    UK
    +332
    exactly the same as putting the dvd in the 360 and having no hd-dvd drive attached
  3. lisnalee
    lisnalee
    May 24, 2005
    1,681
    +206
    I think i read here on the forums that sd dvd's are only upscaled if they are played in the xbox 360 drive itself, someone correct me if im wrong
