SD card
Discussion in 'Photography Forums' started by Exmouse, Jan 12, 2005.
  1. Exmouse
    Exmouse
    My 512Mb Secure Digital card has started behaving odd. All was fine and then it stopped being able to access some files. I can't delete them and several other files appear to get deleted but then reappear although with a file size of zero. Now nothing on the card appears to work but I can still add files that will work. So is it possible to reformat a card? Any suggestions as to what is wrong and would a reformat sort it? If its defunct where is cheap for SD cards nowadays.
  2. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,175
    Norwich
    +795
    I have a couple of smart media cards that have done the same thing and now they work on my pc but will not work in teh camera they were bought for.
    I just bought a 1 gig SD card from blankdiscshop.co.uk for about £50 + vat.
