SD card connector/adapter to facilitate data exchange
anna82sun
Following my previous thread (link), I was wondering if there is a connector or adaptor which would make it easier to physically eject and insert the SD card.
In my case, I would need to switch the SD card almost daily between my two computers, and I thought there might be a device to facilitate this physical process.
And ideas from you are welcome
MaryWhitehouse
Easier in what way? Connect a USB reader to each PC so it's available?
anna82sun
you mean using the SD through an USB reader? I thought, I would need to insert it always "into" the computer (into the SD slot) rather than "through a USB reader"
MaryWhitehouse
If the computer has an sd reader why do you need something else?
anna82sun
it this a card reader? But I would also need an adapter for inserting an SD card here, right?
MaryWhitehouse
Ok you said you had an sd card reader, hence the confusion. That looks like a PCMCIA card slot, quite an old laptop? You need a USB sd card reader but if that laptop only has USB1 sockets then you may find it very slow.
anna82sun
Here we are: It was on the other side. I overlooked
This looks like a SD would fit into :)
MaryWhitehouse
At the bottom is a USB socket. Above is either another PCMCIA slot or a CF card slot. I think that machine is too old to have a sd card reader so you’ll need a usb one.
MaryWhitehouse
Does it make a different in terms of transmission speed which kind of USB reader to choose?
It does. Just by a USB3 one, too fast for that laptop but backwards compatible so will be fine and save buying another for next machine.
anna82sun
...just another question: Can I encrypt everything on the SSD by veracrypt?
Or shall I open a new thread for this question?
MaryWhitehouse
Samsung S95B QD-OLED Review - A Quantum Leap for OLED!
