SD-900 interlaced PAL on plasma
Discussion in 'Blu-ray & DVD Players & Recorders' started by Trevor spencer, Sep 2, 2005.
  1. Trevor spencer
    Trevor spencer
    Jun 23, 2005
    457
    +3
    would this look any good , or would a pal prog scan DVD player do better ?
    thanks
  2. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    How long is your piece of string compared to mine? Unfortunately without more details no one can answer this.
  3. Trevor spencer
    Trevor spencer
    Jun 23, 2005
    457
    +3
    :oops: sorry right
    Panasonic TH42PWD7 running components , i know the SD900 can do NTSC prog scan but what would the interlaced Pal look like
    ive read some post where people think the SD900 can do better interlaced on a plasma than most later spec Prog Scan DvD players
    just wondering if this is true
  4. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    The 900 is a very accomplished DVD player, no worries, there. The interlaced feed to the Panny (NTSC and PAL) is probably the route I would take to your Panny plasma as the deinterlacing is more recent there, however I would look at the 480p as well jus t to check. Certainly my 9000 (model before the 900) and my 9500 (model after) are probably best left out putting interlaced to the screen.
  5. rabrown
    rabrown
    Aug 15, 2005
    67
    +27
    Since you mentioned the SD-9000 I wonder whether you have done any comparisons between the interlaced output of that player and the interlaced output of more recent players. The reason I ask is that I currently have the 9000 and am considering how much benefit, if any, there would be to changing players when I replace my tv. Thanks in advance for any thoughts in this regard.
    Richard
  6. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,065
    London
    +374
    yep it certainly is :thumbsup:
  7. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    9000 Is Still A Great Player
  8. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,065
    London
    +374
    yep all three are VERY good for this, luckily I have all three to compare ;) The SD9000/900/9500 produce stunning results for me fired via interlaced into my plasma or PJ. The 9500 also does progressive with latest firmware installed and also makes a lovely job of it.
