Scvd
Discussion in 'Blu-ray & DVD Players & Recorders' started by atomant, Jan 22, 2002.
  1. atomant
    atomant
    Feb 3, 2001
    9
    England
    I have a Yelo800DVD which supports DVD,SVCD,DVCD,CVD,VCD,CD,OKO,VCD2.0,VCD3.0,CD-R,CD-RW and MP3. But when I tried a SVCD which I put on a CD-RW the disc was loading then said no disc any ideas what is wrong?
    I opened the cd-rw on the Pc and all the flles where there for SVCD.
  2. GarethH
    GarethH
    Aug 31, 2000
    325
    UK
    Try burning on a CD-R!
  3. triplea4uk
    triplea4uk
    Jan 12, 2002
    2,011
    48
    Northants
    +85
    you shouldnt copy vcd or svcd on to cdrw discs it dosnt work on dvd players so try normal cdr disc and if it doesnt work then that means you have set the picture format or radio wrong because the yelo dvd player can only run certain svcd specs.
    I was going to buy a yelo800 do u think it is really worth £160 and can u record a dvd on to a blank video dvd picture quality on the video.
  4. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,575
    Somewhere in South Yorkshire
    +6,095
    Usually not true. CDRWs generally DO work on DVD players. In fact, on most early single-laser DVD players, they work better than CDRs (which often don't work at all on such players).
    And, as atomant says, his player is CDRW compatible.
    There is almost certainly something wrong with the burning software, or the CD writer drive, or a user error in creating the disc. CDRWs are an excellent way of experimenting to get things right without creating a trash can full of unusable CDRs (coasters).
