Screws for wall mounting the bracket
Discussion in 'Home Cinema Buying & Building' started by davegtt, Mar 3, 2005.
  1. davegtt
    davegtt
    Dec 22, 2004
    112
    Hi Guys, Mounting my Viera tonight, so Ive gotta pop into Wickes or BnQ and pick up some screws (as I presume the bracket doesnt come with them?) anyhow, its being mounted on a chimney breast wall so its brick. I was wondering what size screws Im gona need to buy???? dont want it falling off do we :)
    many thanks
    Dave
  2. Rambles
    Rambles
    Jul 14, 2004
    8,315
    UK
    +1,288
    Think the fixings you need should be supplied with the mount - they were with mine.
  3. Tarsh
    Tarsh
    Jan 9, 2005
    52
    9
    Essex
    I mounted mine with 4 'rawl bolts' like these, as recommended by the guys at AV-Sales:
    http://www.screwfix.com/app/sfd/cat/pro.jsp?ts=42936&id=14258
    You can get them in B&Q in packs of 4 (B&Q own make), I haven't got the packet any more, but I'm sure they were size 6 & 60mm long.
    Needed a 12mm diameter hole, I suggest you drill a smaller pilot hole first as then the drill bit is less likely to wander off your mark.
    My bracket is the AV-Sales tilting wall mount & it didn't come with wall fixings (came with loads of bolts & bits to connect to the Plasma though :) )
  4. davegtt
    davegtt
    Dec 22, 2004
    112
    ohh right then, that'd be even better then :) I saw some screw bolts that was approx 5inches long and fairly thick and chunky but a mate laughed at me and said they'd never hold the telly and pointed to something closer to 9inches :eek: thought they was a bit overkill to be honest so I got slightly worried since my DIY skills aint exactly superb
  5. davegtt
    davegtt
    Dec 22, 2004
    112
    Tarsh, thanks for the reply. 60mm long :eek: that all. only 4 of the buggers? hmm, hopefully I should be OK then :) should be an easy job then, will put about an hour aside for it ;)
  6. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    those chunky black ones fit the mount to the screen...you will need something like Tarsh recommends to fit mount to the wall
  7. Tarsh
    Tarsh
    Jan 9, 2005
    52
    9
    Essex
    Have you got someone to help lift the Plasma onto the wall?
    Mine is fairly high, around 6' to the bar the Plasma hooks onto & my 15 year old son struggled to lift it with me. In the end I lifted it on, with him helping to balance it. Not for the faint hearted with 2.5k worth of kit :eek:
  8. davegtt
    davegtt
    Dec 22, 2004
    112
    yeah the misses brother said he'd come round after work to help me :) tell me about it, we've been decorating, at the minute its on the pedastal stand and its being moved once ever 2 days onto the window sill and back (its a bay window dont worry I aint balencing it ;) ) misses struggles with it so theres no way I want her help getting it onto the wall
  9. thehive
    thehive
  10. dvdsubtitles
    dvdsubtitles
    Rawl bolts are the way to go.
    I fitted my Pio 504 to my living room wall using 4 rawl bolts. The wall is breeze blocks/thermalites, not brick, but still plenty strong enough.
    Unfortunately there was almost 2 inches of plaster on top of the wall. From experience fitting some cabinets, using shallow bolts/screws will not hold well enough.
    What I did was to buy rawl bolts where the plug was 2" long (couldn't find any longer!) but the bolt was 6" or 7". Then drill a deep hole (6"-7") and wrap insulating tape around the bolts at an appropriate point to stop the metal plug sliding along the bolt when you insert the whole thing. Tested the mount by standing on it before mounting the plasma :)
    Mat
  11. davegtt
    davegtt
    Dec 22, 2004
    112
    All went swimingly last night :D took about 2 hours ish although we was taking our time as the batteries for the drill was on charge. 8x M8 10mm rawl bolts have done the job, all seems fine. although we heard a bang last night. misses jumped outta bed and ran downstairs to check it was on the wall. I knew it was OK though cause it wasnt that loud of a bang :D looks mighty fine even if I say so myself....
  12. timbo2
    timbo2
    Hi there.
    Getting a bit frantic as I've had my new Viera delivered (TH42PX700B) and I bought a separate non-Panasonic stand for it. Of course, now it turns out that neither the stand or the plasma came with screws for fixing the plasma to the stand bracket.
    Does anyone know what screws I need to fix the two to each other?? Help please !!
    Tim:confused:
