Screws for thermal blocks-ok its been asked before!
Discussion in 'Plasma TVs Forum' started by birdseed, Oct 1, 2005.
  1. birdseed
    birdseed
    Nov 17, 2004
    229
    +5
    Hi all,
    About to mount my pio 436 onto my wall. Since discovered there is a 25mm gap from the front of the plaster to the thermal blocks. the plaster is 10mm of this. there dont appear to be any wooden battons, so i assume theres dabs of plaster which i can percuss out.
    A colleague suggested chemical anchors, but homebase dont sell them, and given the 25mm gap, id feel better with a 120mm screw to stop the leverage.
    I also plan to move house in the next year so dont want to use the mdf/plywood panel direct onto the thermal block routine. Even putting battons in would destroy some plasterboard.
    Which fixings have people used successfully, or more interestingly unsuccessfuly in this situation.
