Screw Size? (please)
DWF
I wonder if a 42PV500 owner that has theirs on the wall would be so kind as to tell me what size of screw goes into the back of the set (or bolt as the case might be) you know the (think there are four) wee holes for fixing the steal wall bracket to the back of the set.
Thank you.
M
mal60908
I will have a look when I get home, they are allen screws, I think M8.. :confused:
