Screensavers
Discussion in 'Plasma TVs Forum' started by atacam, Jul 19, 2004.
  1. atacam
    atacam
    Jul 19, 2004
    460
    Southned on Sea
    +9
    I have been told that you can get screensavers for your plasma?
    Is this true? And where do you get them from?
    BTW I have the Techwood plasma.
    Thanks in advance.
  2. nictry
    nictry
    Apr 28, 2002
    5,780
    Kent
    +645
    Most have some type of screensaver built in usually a white stripe across the screen, alternative is to buy some sort of ssaver type DVD eg aquarium style and run this when you want the screen on but without static images etc. Hope this helps
  3. atacam
    atacam
    Jul 19, 2004
    460
    Southned on Sea
    +9
    Thanks.
    One quick question. How did you get your DVD collection online?
  4. spanky2k
    spanky2k
    Dec 24, 2002
    503
    London
    +49
    What kind of thing are you looking for? If your looking for something really cool looking to display on your cool new plasma then consider connecting a pc to it and displaying some visualisation software connected to a sound input. Have a look at RabidHamster's R4 vis, which is simply incredible!
    Go to www.rabidhamster.org and check it out.
    In fact, I'd recommend it to anyone with a big screened tv to have a look into it, it really is one of the coolest things to see displayed on a huge plasma or tft.
  5. atacam
    atacam
    Jul 19, 2004
    460
    Southned on Sea
    +9
    Thanks I will look into that.
  6. nictry
    nictry
    Apr 28, 2002
    5,780
    Kent
    +645
  7. atacam
    atacam
    Jul 19, 2004
    460
    Southned on Sea
    +9
    Great. Thanks mate.
