Screensaver options in Panasonic menu
Discussion in 'Panasonic TVs Forum' started by Likvid, Mar 12, 2005.
  1. Likvid
    Likvid
    Dec 31, 2004
    497
    +9
    I have played a little with the Panasonics screensaver and the options in there.
    One thing that i really don't understand what it does is the "Peak Limit".
    It was set ON and i turned it OFF, what i noticed was that the picture got alot more punch and much more vibrant and nicer.
    What does it do? as it surely have an impact on the picture quality overall.
  2. spicy_fajita
    spicy_fajita
    I believe it sets a maximum (peak) light output for the plasma and therefore will make bright scenes less bright. It may seem a little stupid to have this picture setting in the screen saver menu but I suppose producing less light lets your plasma last longer, hence, screen saver!
    S
  3. Likvid
    Likvid
    Dec 31, 2004
    497
    +9
    Ok, i have found the answer and everyone says it should be switched off as it surpress the white peak level otherwise.
    Now i got brilliant white text and the picture is sharp with it set to OFF.
