Screens ?
Discussion in 'Projectors, Screens & Video Processors' started by leon, Jun 15, 2001.
  1. leon
    leon
    May 15, 2001
    1,158
    kent
    +67
    Can anyone tell me if i can import a stuart projector screen into the uk.i heard this is much cheaper than using a shop i have been quoted just under £3000 for a 7ft wide electric tensioned screen and my budget cannot reach to that , :(because i need a sony 11ht in about 3 months time to fit with the screen :upgrade time .if you do know of any shops that sell them could you plz leave a link for me ,,,,
    ahh one other thing is there anything just as good as a stuart screen out there and is easy to get hold of......and maybe a bit cheaper
    thx http://www.stewartfilm.com/index.htm
    my home page http://www.ronin100.pwp.blueyonder.co.uk/
  2. squid
    squid
    Feb 26, 2001
    546
    19
    the big uk
    you could try a da-lite
    7 1/2 feet tensioned electric start at £1874
    exact size 132 x 234 cm
    http://www.direkt2u.co.uk/
    i got a da-lite screen and i am more than happy with it
  3. leon
    leon
    May 15, 2001
    1,158
    kent
    +67
    thx for that squid ,,anyone else got anymore ideas i need input guys
    thx again squid
  4. Gordon @ Convergent AV
    Jul 13, 2000
    14,214
    +3,055
    Leon,
    Vu-Tec do some good electric screens with a very heavy fabric that doesn't require tensioning to stay flat. If you can forego the tab-tensioning you can bring the price down considerably and look at other models by Draper, Da-Lite, Owl and SSuk who do Ellie do a screen as well.
    Stewart do several different designs of electric screen. If you have a specific idea on what you require from a screen or if you'd like some help or a competative quote then email me.
    Gordon
