MATT JENNER
Established Member
Hi all
I need some help, I am trying to limit the screen using the limiter, where abouts is it on the canister, and how do you use it, do you have to wind the screen up then turn the bolt, or do you have it wound fully down and do it?
Many thanks
Matt
Many thanks
Matt
