Screens gone green
Discussion in 'Plasma TVs Forum' started by rudy, Aug 16, 2005.
  1. rudy
    rudy
    Jan 2, 2005
    499
    Noticed i had sky on wrong setting(PAL) and changed it to RGB, scart control on. All was fine til this morning when I switched on my Hitachi 32pd5200 and it had a strange green tinge :eek: . By switching back to pal normal colour came back. Obviously i would like the better PQ of RGB setting.
    Whats this about?
  2. philipb
    philipb
    Mar 6, 2002
    2,033
    63
    Swindon
    +149
    Jiggle the scart lead about a bit. Sounds like the scart plug is not properly seated and the red terminal is not inputting. This would not be a problem on a composite signal.
  3. rudy
    rudy
    Jan 2, 2005
    499
    Long overdue a change to comp. cheers for that
  4. Korum
    Korum
    Feb 19, 2005
    4,352
    Stockton-on-Tees
    +701
    quote 'Long overdue a change to comp'
    What do you mean by this Rudy ? Are you getting it mixed up with a component connection.
    PAL normal on Sky is composite and looks bloody awful.Sounds like a dodgy scart lead to me,go and get a nice new expensive one, RGB scart is the best picture possible on Sky at the moment.
  5. philipb
    philipb
    Mar 6, 2002
    2,033
    63
    Swindon
    +149
    Apart from SDI of course, but that's a whole other story.
  6. Korum
    Korum
    Feb 19, 2005
    4,352
    Stockton-on-Tees
    +701
    come on phillip,you know what i mean, if Rudy is contemplating a long overdue change to composite I don't think he's considering an SDI connection.
    Sorry, I should have said 'RGB scart is the best picture possible on Sky at the moment without modding your Digibox'
  7. rudy
    rudy
    Jan 2, 2005
    499
    Sorry, i should have explained better. I have been meaning to buy a new scart (sky) to component(plasma) lead. The scart connection on the Hitachi is'nt supposed to be great.
  8. Badger0-0
    Badger0-0
    May 30, 2005
    20,593
    Spaghetti Junction (really)
    +1,921
    I agree.
    I've seen some stupid greens on the 7200.
    Running the AVIA disc helped a bit.
    I hope the HD Sky boxes are better.
  9. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,702
    The Borders
    +3,071
    Hello all
    Now I remember why its best to keep away from the Plasma Forum :)
    rudy - your SCART equipped Digibox can Output Composite Video (often labelled as PAL in the Digibox set up menu) or RGB.
    There is no Provision for a YUV 'Component' output on 99% of Digibox designs - one or two Freeview units do offer YUV on SCART but as I say they are rare.
    If you have a TV with a SCART Input and it too is RGB enabled there is little or no reason to contemplate a move to convert your RGB source signal to YUV; you cant do it with a cable you require an active transcoder (which means spending £150+ for no visible benefit to your picture quality).
    Have you confirmed your TV is set to RGB on its SCART Input - possibly it 'forgot' this setting when you powered it down. As others have said a loose SCART socket is another possibility - this can happen with expensive SCART cables just as readily as it does with inexpensive SCART cables.
    Best regards
    Joe
    PS Badger0-0 - you aren't suggesting your Hitachi is anything but perfect; are you!!!
  10. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    I've found, as with Pioneers, that the component input on Hitachis is noticeably better than scart. Why do so many plasmas have trouble with scart?
  11. Badger0-0
    Badger0-0
    May 30, 2005
    20,593
    +1,921
    LOL
    Hi Joe,
    I've never said it is perfect mate.
    Regardless of what people say, the 7200 has good blacks when set up properly, just not as good as the Panny 6 and I'm very happy with it.
    I assume you're referring to the other thread.
    I just like to see two sides in a discussion :smashin:
