Screens blank after repair
Discussion in 'Mobile Phones Forum' started by doug62, Apr 26, 2007.
  1. doug62
    doug62
    Oct 3, 2004
    53
    Hi all
    I have recently fixed my Motorola V3's front lcd screen glass cover which was cracked and the two lcd screens are now both blank. I removed the front cover and the pulled the broken glass off and put the new glass on as instructed on the net. The phone still rings (altho with a different ringtone than i had before) and can dial out. One thing I am worried about is that I removed the broken glass with the edge of a metal screwdriver and then read afterward that i should have used a plastic adge. Could I have electrostatically damaged the circuitry? I have checked the ribbon connections best i can and they seem fine. Any help would be greatly appreciated.
    Regards
    Doug
  2. ram33
    ram33
    May 28, 2005
    1,150
    48
    +61
    for both to not work it looks like you may have caught something with the screwdriver, if you havent damaged the ribbon then you will need complete lcd set - about £20
