Screenplay 7210 Owners - mounting bolts help?
Home Cinema Hero
Hi all,
I have a Screenplay 7210 which I've had on a desktop for a while but now I've moved, I want to wall mount it. Money's a bit tight, having moved, so I was hoping to simply hang it under a shelf, putting the bolts through from the top of the shelf and screwing them into place on the underside of the PJ.
First up, does that sound like a reasonable idea? I was planning to get quite long bolts so there was clearance above for heat purposes.
Secondly, anyone got any idea what size bolts (as in diameter) I'd need?
Many thanks,
Tom
Muf
Leaving a clearance is a god idea Tom as the casing gets pretty hot especially in the vicinity of the lamp. If you can't get bolts long enough you could get threaded rod and plenty of nuts and washers. It is a while since I had my 7210 but I am 99% sure that the thread size was M4.
Jim.
LG G1 OLED Evo TV and SVS SB-1000 Pro subwoofer reviews, Samsung OLED rumours and more...
