Screenplay 4805 throw ratio.
Discussion in 'Projectors, Screens & Video Processors' started by gorwig, Mar 1, 2005.
  1. gorwig
    gorwig
    Aug 2, 2004
    205
    Abertawe
    I`m thinking of replacing my Panasonic ptae300 with a 4805. However it would have to be mounted about 15 feet away from my 67 ins wide screen. According to the throw ratio calculator on the infocus website this would be much too far to obtain a 67 ins wide picture. Does anyone know if the lenses are interchangable on the screenplay range or can you buy a telephoto attachment? The sp5700s throw ratio is much bigger and would do the job (but I can`t afford one).
  2. Oakleyspatz
    Oakleyspatz
    Oct 9, 2004
    3,704
    Woking
    +237
    You are right with your calculations, from 15 foot away, the smallest image on the 4805 would be 85 inches across, you would need to have the projector 12 foot away for a 67 inch wide image. The lens is unfortunately not interchangeable on the 4805 so I think you'll either have to buy a bigger screen, or ceiling mount the projector 12 foot from the screen.
  3. john<|>nhoj
    john<|>nhoj
