SCreenplay 4805 thread size for 3 holes for ceiling mount...
Discussion in 'Projectors, Screens & Video Processors' started by john<|>nhoj, Apr 14, 2005.
  1. john<|>nhoj
    john<|>nhoj
    I am just about to mount my 4805 in a wall mounted box upside down, unfortunately I need the thread size which is a wierd one to mount the projector on the shelf upside down.
    I have worked it out that it is 3.5mm but some wierd pitch not available in B&Q and need either studding (threaded rod) or long bolts as it will fit a IKEA LACK Unit on the wall and this is ~50mm wide.
    HELP...
  2. dooby44
    dooby44
    They are standard M4 bolts, the same as used in electrical sockets to hold the cover on.
  3. binbag
    binbag
    Jun 16, 2004
    1,717
    North Kent Coast, SE UK
    +81
    Make sure that you don't go 'in' over 10mm either - theres a circuit board underneath.
