Screenplay 4805 Please help
Discussion in 'Projectors, Screens & Video Processors' started by abspag, May 30, 2005.
  1. abspag
    abspag
    Pleas help, my projector seems to have locked onto a DVI signal. I now need to change it back to component signal trough the BNC. connections only to find that all I get is a pink picture. Does anyone know how to get the projector to lose its lock and accept an other input. Any advice would be much appreciated.
  2. cyberheater
    cyberheater
    Apr 3, 2003
    3,225
    Scotland
    +179
    Have you tried removing all video cables and power cycle the machine. Then connect only the component and work your way up from there.
  3. abspag
    abspag
    Thanks for the reply I am a bit of a thicko how do I recycle to get it to lock onto the component signal
  4. cyberheater
    cyberheater
    Apr 3, 2003
    3,225
    Scotland
    +179
    Power the unit off. Unplug the power cable. Wait a minute. Then reseat the power cable and power back on.
  5. Oakleyspatz
    Oakleyspatz
    Oct 9, 2004
    3,684
    Woking
    +230
    You've obviously used the 'auto image' button? Make sure that in the picture setting menu, the other connection options are selected or 'ticked'. If you only connect component and select 'auto image', assuming component has been 'ticked' in the menu, then it should lock onto component fairly quickly.
  6. abspag
    abspag
    Thanks I will give that a try
  7. abspag
    abspag
    Thanks for all yor help. The problem was with the projector in the menu a setting for colour space needed to be set for rgb and this sorted the problem :clap:
