Screenplay 4800 vs. Panasonic AE200
Discussion in 'Projectors, Screens & Video Processors' started by bobbetts, May 15, 2004.
  1. bobbetts
    bobbetts
    Dec 13, 2002
    164
    Norfolk
    Looking for some advice on the above please.
    I have read a number of threads on the qualities of the two projctors. I have also read the avsforums on the X1 (believe it to be the same machine....as per projectorcentral) I am just wondering, given the choice of each machine at the same price which one you would recommend.
    Is one better than the other or is it just a case of pick one. My main priority is getting an as cinematic experience as possible, given the limited budget. Do both provide a good quality 3d image?
    Bob
    P.S If anyone fancies throwing in alternatives....cheap alternatives (<£900) then please feel free.
  2. stevos
    stevos
    May 16, 2004
    6,133
    +567
    I can't help choosing between the two.
    However I own a 4800, and after a few hours run in, i am now very happy with the picture.
    I am running it with my Denon 2800mk2 via the dvd player progressive scan board.
    The board on the DLP is very poor, i would suggest looking else where if you're dvd player doesn't have a good progressive scan board.
    I hope this was some help
  3. bobbetts
    bobbetts
    Dec 13, 2002
    164
    Norfolk
    Thanks for the input, at present I'd be looking to use either RGB scart or S-Video as my DVD doesn't have component....not sure if this is relevant.
    I am also hoping to use my PS2 and Xbox throught the projector, which, considering I have all the scart leads and switcher etc. means cables and connectivity can be easily put in place, with an accepted pq loss, but I can only afford one step at a time. This leads me to the Panasonic range, but it worries me that I may be losing picture quality for the sake of conveniance, i.e. unplugging leads etc.
