screened audio cable.
T0rNaDo
i need around 10 meters of audio cable to go between
me av reciever and subwoofer.
as im getting the hummmmmmm
as the cable im using is normal speaker cable. with rca plugs each end.
and it runs along side power cables.
would this do the job ?
http://www.maplin.co.uk/Module.aspx?ModuleNo=125&doy=6m11D
L
loadsofleads
Hi Tornado, to be honest, your better off getting a dedicated sub-woofer cable. Supra sell a very high qulaity screened sub-woofer cable that would probably be ideal for your setup. :thumbsup:
T0rNaDo
supra dedicated sub-woofer cable
thxs for your reply.
il do a search on google... for it...
T0rNaDo
ouch...... around £60 to £70 ish for a 10m cable..
any recommendations.....
needs to be 10 meters min
T0rNaDo
Trending threads
