screenburn concern on pw7
Discussion in 'Plasma TVs Forum' started by pioneerman, Mar 23, 2005.
  1. pioneerman
    pioneerman
    Mar 25, 2004
    2,530
    71
    surrey
    +63
    I have the mediabox the picture through component is very good,progressive scan. my picture quality through the scart rgb on sky and playstation 2 is also very good.but at some stage i will sell the media box and go the other route js etc. one thing that does concern me is the lack of features mainly the screensaver and the wobble,which if i understand it correctly-its unnoticeable to the eye but moves the picture very slightly to aviod screenburn.also without this function can anyone recommend the maximum time to have a paused image on screen ie. my sky plus and logos,this does concern me,as im sure it would other media box owners.
  2. Brooktop
    Brooktop
    Feb 2, 2005
    2,104
    Nottingham
    +93
    don't get too concerned. Don't have the picture on 'dynamic' (which looks too garish to me anyway). Most of the channels with logos tend to have ad breaks every 10-15 mins, so simply channel hop then! (better than sitting through another 'sweety the chick' ringtone ad anyway!)
  3. Piers
    Piers
    Dec 11, 2002
    1,991
    Cheshire
    +229
    The PW7 appears to be almost bomb proof as far as screen burn is concerned. Don't leave it with a static image for 4+ hours, probably don't run it in dynamic mode which looks horrible anyway - otherwise don't worry.
    Piers
  4. pioneerman
    pioneerman
    Mar 25, 2004
    2,530
    71
    surrey
    +63
    i have it set on cinema,with low contrast and brightness but about half way on sharpness.thanks for the reply piers. :smashin:
  5. w3dal
    w3dal
    Aug 4, 2002
    5,050
    Chelmsford, Essex
    +587
    The same settings as me Fella..... Looks good doesnt it :smashin:
    Dal
