Screen with variable masking
Discussion in 'Projectors, Screens & Video Processors' started by theritz, Jun 28, 2003.
  1. theritz
    theritz
    Aug 17, 2002
    2,455
    Ireland
    +27
    I've recently built a screenwall with variable masking in my movie room - check here for details and pictures. This arrangement was pretty easy to instal, and is well worth considering if you already have a diy screen. A similar "screenwall" with masking panels could be constructed in front of a pull down screen.
    Thanks to Vexorg for ideas, advice and assistance.
    Sean G.
  2. Messiah
    Messiah
    Apr 22, 2002
    7,616
    +338
    Nice one. I'd see the doctor about that growth on your back though :) (nice growth though it is ;) )
  3. derekduvalle
    derekduvalle
    Excellent idea.
    I have a similar system, except my masking panels are hooked on clips attatched to the main screen surround.
    I have been looking for a way to do what you have and to possibly motorise the system.
    I hope you don't mind if I copy your system and try to motorise it!!!
  4. theritz
    theritz
    Aug 17, 2002
    2,455
    Ireland
    +27
    Hey, the whole thing is to share ideas !
    I had thought of using window winder motors, one on each side, but the business of getting them to stop in exactly the right place is probably beyond me. I've also found that it takes a little "tweaking" to get the masks into exactly the "right" position - this is much easier to do by hand, tbh, and I only need to change it every once in a while, so it's no trouble.
    All the best,
    Sean G.
  5. loftfuton
    loftfuton
    Feb 4, 2003
    93
    BELFAST
    Read with interest this post, and will give something like it a go. This is probably a stupid question, but when you spoke about HiDef, what do you mean ??.
    Harry
  6. theritz
    theritz
    Aug 17, 2002
    2,455
    Ireland
    +27
    I was referring to High Definition - 720 or 1080 lines of resolution - seriously has to be seen to be believed - detail, sharpness and colour like you wouldn't believe. Remeber the first time you saw DVD after being used to VHS ?? Well HD material is a similar step change, imo. I received a super range of clips fom Kramer - big thanks - and run it directly from the hard drive on my hcpc.
    All the best,
    Sean G.
