Screen type?
Discussion in 'Projectors, Screens & Video Processors' started by sercomber6, Sep 13, 2004.
  1. sercomber6
    sercomber6
    This is probably going to be the simplest answer for most of you but i'm very new to this.
    What is the difference between a type s and a type d projector screen???
    :rolleyes:
  2. Otto
    Otto
    Jun 19, 2003
    322
    28
    +61
    The type of fabrics you mentioned are manufacturer specific types and don't mean anything really useful.
    Useful values would be:
    1. Type of fabric:e.g. reflective, retroreflective, specular, rear projection
    2. Gain and viewing angle
    3. Weight per sq.m and material thickness
    Other features:
    1. Black borders
    2. black back
    3. black drop
    The above-mentioned items allow you to compare different fabrics. Combine this with the experience of the people using the forum and you should be able to make the right decision.
    Good luck,
    Otto
