Screen suggestions
Discussion in 'Projectors, Screens & Video Processors' started by Nikumba, Sep 24, 2004.
  1. Nikumba
    Nikumba
    Aug 20, 2004
    231
    +9
    I am after a celing mounted screen to be used with the AE700 when it is released, after a ceiling mounted one and have about £300 to spend.
    Whats the best screen to fit that spec?
    Nikumba
  2. FlyingBig
    FlyingBig
    Apr 11, 2004
    545
    Lisburn
    I am on the same boat as you....just got fustrated with my screen and ripped the material off and tried to make a ripple free screen. I failed. So i am looking for a fixed projection screen that is ripple free. If i find a good deal ill let you know.
  3. felisberto
    felisberto
    I know that this must be recorrent for many of you, but i to need some assistance.
    I'm in the same situation than Nikumba, and i've been investigating some option:
    draper luma
    HC White Matte Dalite
    Projecta
    Lumene
    But mainly the first two. What can you tell me aboout those choices ? Are they other choices in the price range listed above ?
