screen speakers as centre channel?
Discussion in 'Plasma TVs Forum' started by esrg, Aug 5, 2004.
  1. esrg
    esrg
    After much diliberation and review of these forums (most helpful) I've just taken delivery of my 42PD5200. :clap:
    This model comes with speakers and I want to see if can use them as the centre for 5.1. Anyone done this before? Use their screen speakers as the centre channel?
    I'm not sure about the best way to go about it is. I am planning on just splitting the signal from the receiver and wiring direct into speakers along with the output from the inbuilt tuner.
    Does anyone know a better way?
  2. Blu Ray
    Blu Ray
    Jun 14, 2004
    496
    Chorley, Lancs
    +12
    You're planning to use the 2 speakers as the center channel? I don't really think this is such a good plan, you're better having a 5.1 speaker set of compatible speakers. My speakers from my 42PD5300 have never left their box, don't know what to do with them really.
  3. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    But the hitachi has an audio input for this purpose doesn't it? Blu Ray, I tend to agree with you, but it's possible, I think you use the centre pre out on your amp. They will sound like poxy TV speakers, but will work. I wouldn't bother personally, but hey, that's just me. I have 4 centre speakers already.
  4. Messiah
    Messiah
    Apr 22, 2002
    7,616
    +338
    Isn't that just being plain greedy? :eek: :D
  5. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,765
    The Borders
    +3,088
    esrg
    What's the rest of your 5:1 system going to be - as others have said its technically possible to use one (or both) of the Plasma speakers as part of a 5:1 system - though its equally as possible that it will be nigh on impossible to get a decent sound out of these speakers and they certainly wont 'sound' like the majority of Front Left and Right speakers in any half decent 5:1 system.
    The Centre channel handles a huge amount of info in most Movies and TV shows and getting it wrong destroys the surround sound experience; like others I'd not want to use my Plasma speakers as part of my 5:1 system.
    Best regards
    Joe
  6. esrg
    esrg
    The issue is my 5.1 is bit of a hybrid. Front 3 bose acoustimass (3.1) and then my rear surrounds are gale 30's. Then a gale 3080 as a sub because the bose comes from the speaker channels and there no LF signals sent there with 5.1 decoding(I think). Anyway I digress, The bose centre speaker is an ugly brut and sticks out miles and the Mrs wont have it! Plus, it's cr*p for mid frequencies.
    Unless I can get a Flat centre that wont stick miles out of the wall I'm onto a loser.
    Although, the audio in sounds like a good plan. Haven't had the TV out of the box yet so missed that option (thanks Maw). The other consideration is that I don't really want things like Eastenders & 'House Improver' etc in 5.1 so want the TV speakers for normal tele.
    Are the speakers really that bad on the Hitachi it appeared to have good reviews?
  7. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    I can now see the logic though I get on well with pro-logic for ordinary TV (don't watch soaps though). The speakers might well be better than bose, I refuse to capitalise that noun. As to reviews, as this forum is sponsored by one of the magazines, my scorn cannot be adequately expressed.
  8. esrg
    esrg
    hmmm, okay, so the audio in... Not sure what my receiver will do. (Sony STRD495- You can tell I'm on a tight budget right!) There is a std phono audio out but I don't think I'll be able to send only the centre signal through it.
    I think one may be a trial and error thing.
  9. siy
    siy
    The speakers on the 5300 arent actually that bad - Ive been quite impressed to be honest.
    I was in the same situation as you - but didnt want to get rid of my mission centtre speaker - so i kept it and cut a hole in the wall under the plasma so that it sits flush - really pleased with the result
  10. esrg
    esrg
    Well it's reassuring you rate the Tv speakers, but they're not good enough to stop you hacking at the wall ;)
    hmmm, hadn't thought of cutting holes in the wall. That's pretty hardcore. Mine's on a firebreast though so I may end up frazzling the back of any potential protrusion.
  11. siy
    siy
    Well - to be honest I didnt really think about using the tv speakers as a centre channel. My wife uses them for \Corrie/eastenders etc....but they are pretty good.
    I wanted to keep the same speakers and centre so the wall toook a beating
