Screen size
Discussion in 'Projectors, Screens & Video Processors' started by Dak, Dec 24, 2002.
  1. Dak
    Dak
    Sep 23, 2002
    251
    Chislehurst
    I have asked this question before within another thread ,but wanted to throw it open as I still am a little hesitant to commit to a pj / screen:
    I have looked at various pj's (currently considering the NEC HT1000 or the Sony HS10) and am considering screen sizes. I have looked at the various (very helpful) calculators that help work out the sizes for throw distances etc but my question is a bit less technical:
    How large a screen is ideal for a lounge with a 12 foot throw distance from a daily watching it point of view? ie if I am sat 12 feet away, how big is suitable to see it all without craning the neck or getting tennis neck etc etc?
    I am hoping for some comments from those that live with a pj in a similar circumstance......
    Dak
  2. gwbailey
    gwbailey
    Dak,
    I think the general rule of thumb is you sit no less then 1.5X the screen width, so if I was you I'd go with a 80"x45" 16:9 screen.
    Hope this helps!
  3. Dan18
    Dan18
    Oct 9, 2002
    69
    Dak,
    I'm a projector newbie and just got a Sony HS10. The 1.5 x rule is just a guide. I am projecting onto our wall until I decide on the final screen size but bigger seems to be better. I just zoom up to the maximum size in most cases and it looks fantastic. With this projector there is hardly any loss of quality as the picture gets larger. I have not seen any screen-door and the cinema-like experience is great. I think its worth experimenting before buying your screen.
  4. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    The big screen looks big, but remember, in time you will start to see the finer details at which point you may decide a smaller screen would be better. I definitely wouldnt go beyond 80 inch
  5. Smurfin
    Smurfin
    Aug 13, 2002
    21,423
    +4,355
    I have a 110" diagonal image, sitting 11' away, and I still love the damn thing.
    Buns is right that after a while you do notice more flaws, but personally I wouldn't let that put me off.
    I only have one problem....8' wide is too damn small now:D
  6. Dak
    Dak
    Sep 23, 2002
    251
    Chislehurst
    Thanks Guys.
    I was going to project from 12 foot using the sideshot feature but having heard the criticisms of the effect this has on the picture may put it under the coffee table.
    Throw then is just 6 foot........
  7. GoggleBoy
    GoggleBoy
    6 foot with a HS10? you will get a small image m8 49 in max. You will need to find a projectpr with a shorter throw. I am in the same boat and am looking at a Z1 or perhaps a TW100 etc.
  8. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,424
    Somewhere in South Yorkshire
    +5,823
    Mount it upside down on the ceiling, central to the screen laterally. Just do it.
  9. Dak
    Dak
    Sep 23, 2002
    251
    Chislehurst
    Large chandelier blocks that option.........
  10. Zig
    Zig
    Zig puts the "Large chandelier " into the wheelie bin for Dak
  11. Messiah
    Messiah
    Apr 22, 2002
    7,616
    +338
    You could always get a quick release light fitting which takes about 1 second to remove the light. B&Q sell them and are meant for taking them down for cleaning etc. Look like a brass ceiling rose and work fantastically. Cost about £12. Brilliant. Used one all the time when I had a pj in the lounge.
    Only downer, you need to find somewhere to put the chandelier when your watching TV. After all, you're unlikely to have them on while watching I guess.
