Screen size
Discussion in 'Projectors, Screens & Video Processors' started by zero7, Mar 16, 2006.
  1. zero7
    zero7
    Feb 19, 2004
    822
    3
    Warwick
    +77
    I'm starting to get all the bits for my dedicated room, it's going to be 15ft long and my seating position will be 10ft from the screen. I was thinking along the lines of a 6ft screen, would this look ok.
  2. mkjustuk
    mkjustuk
    Mar 4, 2002
    455
    Cheshire
    +14
    That would look fine, something between 6 and 7 foot would suit a 10 foot seating position. Anything over 7 foot will be too big.
  3. jimbobaggins
    jimbobaggins
    Dec 29, 2002
    491
    Up North
    +18
    I think I would get a 10 foot screen as it is bigger.
  4. GBDG1
    GBDG1
    Feb 5, 2006
    7,447
    +1,260
    I disagree, a bigger screen is obviously bigger, but a smaller screen is also smaller, which obviously has it's advantages/disadvantages.
  5. jimbobaggins
    jimbobaggins
    Dec 29, 2002
    491
    Up North
    +18
    I think the problem is that if you only get a smaller screen and then later you want a bigger one, the only solution is to stretch it, which creates wrinkles.
    A much better idea is to get a larger one and paint the edges with removable black paint. If you want it bigger then you can remove the paint.
    Alternatively if you need to constantly change the size of the screen, you could use four black cloths stapled to it instead.
  6. zero7
    zero7
    Feb 19, 2004
    822
    3
    Warwick
    +77
    I think I'll go with a 7ft Screen, I will cut out some cardboard and stick it to thew wall to get some idea what size it will look like.
    I really don't want ot be moving my head from side to side int order to keep up with action. That's why I always closer to the back when visiting the cinema.
  7. GBDG1
    GBDG1
    Feb 5, 2006
    7,447
    +1,260
    suppose you could go for the 7ft, if you wanted to.
  8. jimbobaggins
    jimbobaggins
    Dec 29, 2002
    491
    Up North
    +18
    From the second paragraph are we safe to assume that you are mainly watching porn??
    If so I recommend a 10ft screen or even a 12ft one.
  9. Transwarp
    Transwarp
    LOL
