Screen size versus minimum viewing distance?
Discussion in 'Projectors, Screens & Video Processors' started by cunning viewer, Dec 13, 2004.
  1. cunning viewer
    cunning viewer
    Dec 13, 2004
    There seems to be some variety of opinion regarding the tradeoff between screen size and viewing distance, and I'd be interested in your opinions.
    I'm planning a setup where the time I will be most interested in picture quality will be when watching widescreen DVDs, hence I plan a 16:9 screen format and an XGA projector.
    A single bank of seats, around 10 foot from the screen.
    TheFinalClick suggests that I should have my row of seats approximately two screen heights away from the screen:
    http://www.thefinalclick.com/shop/customer/pages.php?pageid=10
    This suggests a maximum screen height of about 5ft, which implies a 119 inch (302cm) diagonal screen on 16:9, with a screen 58in high by 104 in wide (147 by 264 cm).
    So far so good.
    Optoma suggest a minumum viewing distance of 1.5 times screen WIDTH, so you do not spot the "screen door" effect:
    http://www.optomahometheater.com/howto/guide.htm
    Under this guideline, my 119" 16:9 ratio screen is too large, but assuming that Optoma were thinking about a 4:3 aspect ratio when they set their guideline, I should be ok (in 4:3 aspect, 1.5 times width = twice height)
    So as long as I use a native 16:9 projector I don't have to worry.
    First Question: Or do I?
    But there's more...
    Projection Screens suggest a minimum viewing distance of TWICE the width, being the limit at which the human eye can take in the whole image.
    http://www.projectionscreens.com.au/size.htm
    So they imply a 60 inch width, which in 16:9 is only a 69 inch diagonal, almost a quarter of the screen size I had in mind.
    This would also imply an image about four times as bright as the larger diagonal screen, which might be somewhat over the top.
    Question: Am I kidding myself with my plans for a 119" diagonal screen, and should I scale back to something smaller? And why? If so, how much smaller?
    If your answer depends on the projector I am using, I am planning an Optoma H56A
  2. stuthemong
    stuthemong
    Dec 31, 2002
    457
    +6
    TBH it is all to do with personal preference.
    A lot of people will disagree with me (bring it on), but i really think that the current trend for recommending small screens is the proliferation of DLP, a technology that suffers as the screen gets bigger, as rainbowing becomes far more pronounced.
    Personally i like to sit 1x screen width so i get a massive field of view of image. OK its probably not best for critical viewing, as you can see pixel makeup, but TBH, I find it far more involving like this, and cant understand why anyone would pay a few £K to get a projecotr, project a 60" image, and then sit so far away, you're just as well off with a 32" TV from a couple of metres :)
    If you sit 1.5x screen width / 2x screen height, i am sure you will be fine - though before spending £££ on a screen, id get your projector and test different sizes. this is theonly way you will know for sure.
    Stu
  3. fortean
    fortean
    Nov 28, 2004
    825
    Chorley
    +71
    I agree with stuthemong. It's your home cinema, have it whatever size you want. You could try projecting on to a white sheet just to get an impression of how it feels. I sit about 11 and half feet from my 8 foot screen (6 foot verticle in 4:3 mode), so that's about 1.5 times width and 2 x height. It's a new screen and has replaced a 7 foot screen that was mounted about 12 inches further away. I definately prefer the larger image. My projector is a CRT so I've no experience on pixelation at this size, just horizontal lines on 4:3 NTSC.
