screen size? from 9 feet
Discussion in 'Projectors, Screens & Video Processors' started by jcdub, Dec 5, 2003.
  1. jcdub
    jcdub
    Dec 5, 2003
    17
    what screen width would be best for viewing 16:9 from around 9 feet
  2. WeirdFish
    WeirdFish
    Jun 28, 2003
    881
    Hadleigh, Essex
    +15
    I wouldnt go bigger than 6ft wide.
  3. SSB
    SSB
    Jun 16, 2003
    1,510
    63
    North Cumbria
    +173
    I think the rule of thumb is the size of the screen should be about 2/3 your distance from the screen. Or, conversely, your sitting distance from the screen should be about 1.5 times the width of the screen.
    Rather neatly this supports WierdFish's suggestion that you get a 6 foot screen. :)
  4. Godfather
    Godfather
    Feb 12, 2001
    2,223
    63
    Edinburgh
    +224
    I sit 12 feet away and my 6 foot screen is big enough for me. So definitely no bigger than that in your situation.
  5. Kramer
    Kramer
    As stated, usually 1.5 times screen width/viewing distance minimum but depends on the projector.
    Some projectors (lower resolution) are best viewed from 1.8 to 2 times screen width away, higher resolution/CRT you might get away with 1.4/1.5.
    6' wide is your maximum size IMO.
