Screen Size and distance
Discussion in 'Projectors, Screens & Video Processors' started by bass007, May 27, 2004.
  1. bass007
    bass007
    Apr 8, 2004
    1,514
    london
    +36
    Hi all,
    Looking to get the Infous 4800, and I need a screen, being a total novice is there a formula to follow to get the best screen size? also if for example I can accomodate a 3m screen would I get a better picture by reducing the screen size?
  2. ntslik
    ntslik
    Jul 26, 2002
    620
    Cambridgeshire
    +10
    You should try and stick to a rule of half the distance from the screen to the viewing position, this is more important, you will get a better picture the smaller you go,
    what is you viewing distance??
  3. bass007
    bass007
    Apr 8, 2004
    1,514
    london
    +36
    viewing distance about 2.75-300m
