Screen Shift
Discussion in 'Projectors, Screens & Video Processors' started by johna, Sep 21, 2001.
  1. johna
    johna
    Dec 15, 2000
    874
    Kent
    +4
    Hi everyone.
    I have recently hooked up my sat box to a letropacks RGB-S-Video convertor and then hooked to my Amp - then to my Projector (Sony CX1) however I have lost about an ince or so of the left hand side - the screen has shifted.
    Has anyone else had this problem? Could it be a faulty convertor?
    Answers on a postcard please
    <br />Thanks
  2. Paul D
    Paul D
    Dec 27, 2000
    2,781
    Manchester
    +550
    I have the same unit. Yes the image does shift left, it's something to do with macro defeat. Open up the unit and you will see a small white "pot". Whilst watching the screen, adjust until the picture goes off and then slowly turn back. You will not be able to get it perfect, but better than it is now. Lektropacks are aware of this problem. In fact it's them who recommend you open the unit and adjust. Ignore the seal that states it will invalidate your warranty. Don't worry about high voltage, as long as yours uses the low voltage adaptor!.
  3. johna
    johna
    Dec 15, 2000
    874
    Kent
    +4
    Ahhh!!!
    Thank You very much.
