Screen save/screen wipe. Bad for lifespan?
Discussion in 'Plasma TVs Forum' started by rudy, Jun 26, 2005.
  1. rudy
    rudy
    Jan 2, 2005
    499
    I've a humble Hitachi 32pd5200 and was reading on another thread that using the screen save/wipe to avoid burn in can drastically reduce the lifespan of the tv.
    as i have been using this function i would like to know if I should turn this off.
    Thanks in advance
  2. johndon
    johndon
    Feb 3, 2002
    1,971
    63
    +108
    I believe it can reduce the lifespan as it effectively 'burns' all the screen to the same extent which is how it gets rid of burnt in images. I'd have no problem turning it off, I've never even used it on my 5300.
    John
  3. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +411
    It's something you use when you have to, rather than as any sort of routine. Theoretically it does shorten the life of the panel, but by how much it's hard to say. Watching a bright movie would do pretty much the same, so taking it to extreme, you need to keep your movie watching to 'LOTR' and maybe 'The Matrix'. Then your screen will last for ever and you will die of boredom. On the other hand, I'd live your life as you see fit, watch what you like, in the sure and certain knowlege your screen will eventually wear out, in about 10 odd year's time. Is that a problem?
  4. rudy
    rudy
    Jan 2, 2005
    499
    Can't turn it off! aaargh
