Deleted member 186976
Heres a question:
What happens if after you spend 2 or 3 months with your new Plasma tv on "run-in" settings. So you figure you can turn it up to a reasonable brightness etc but then after 3 months you find you are getting MAJOR screen retention....and its not going away.
What do you do? Manufacturer/warranty wont be any good even though you follow the correct instructions (if even there is any within the manual which IMO there absolutely should be considering the price of the purchase) to make sure you DONT get screen retention.
Im sure i saw an older thread where this happened to someone depsite the fact they were very careful with the screen settings.
All that time you have been zooming into pictures, making sure logos arent onscreen, restricting gaming use to a mere minimum.. .never leaving the set on long with static images etc. And yet it isnt enough... what then?
I might add that doing all this, does it not severely restrict the viewing pleasure??? (a bit like buying a ferrari with a dodgy engine so only taking it up to 50mph because if you take it over that speed there is chance it will break down)
This imo is the major thing which puts me off plasmas. Babysitting a tv for months on end and it still might not be enough.
