screen resolution problem
Northerner
Since retuning my Humax 9150T, I now have a screen resolution problem. Virtually every channel (but not all) display with thick black lines at top and bottom of screen in 16:9 format. The PVR is connected to an LG 32LX2R LCD screen via the AV2 scart.
I also have a Freesat HD box which has been retuned and is connected via the HDMI input. This has no resolution problems at all and all channels display in 16:9 resolution correctly
Anybody got any ideas on what is causing this?:confused:
D
Deleted member 36193
Have you done a system reset before retuning?
I didn't at first, and though I didn't get your problem, apparently you have to do this first with the Humax boxes.
You will have to reset your preferences afterwards, telling it the type of telly you have etc, so check it knows you're plugged into a widescreen TV.
Freesat wasn't part of the system reorganisation.
