Screen repair
Discussion in 'Projectors, Screens & Video Processors' started by simadan, Sep 1, 2005.
  1. simadan
    simadan
    I have a screen for viewing but it is old and dirty. Does anyone know of a way to clean a screen, or is there a particular type of paint that can be applied to make the screen a clean white background?
  2. fortean
    fortean
    Nov 28, 2004
    825
    Chorley
    +71
    When I was trying out different materials for my multi format screen conversion I had to remove adhesive from the screen many times. I found Pledge did the job best. I used quite a lot of it. Spray it on so that you have a creamy covering and leave it for about an hour. I used a blunt edged knife to scrape it off with the glue; like shaving it. Try it on a small area first to see how well it works. No point covering the screen with Pledge if it won't shift the dirt.
