Screen ratio's on philips 32pf9986
Discussion in 'Philips TVs Forum' started by nnicol, Mar 18, 2005.
Tags:
  1. nnicol
    nnicol
    Feb 4, 2005
    255
    5
    32
    +40
    I have just got my new set today and am so far very pleased. The only thing is that it won't switch from 4:3 to widescreen in any setting wether it be for the dvd player or sky. Is this a feature of the set or am I missing something. Everything is connected by fully wired IXOS and one Vivanco scart lead. Please can someone help. Thank you.
  2. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    Dumfries, SW Scotland.
    +9
    I don't understand the problem...are you saying that you cannot adjust the picture format using the remote at all?
    Jimmy
  3. Rob1698
    Rob1698
    You mean it is not switching automatically?
    Indeed it doesn't. That is a misfeature of this set.
    The only thing it can do is "automatic" format change in which it will try to use as much of the screen as possible. In 16:9 format this is OK, but in 4:3 it horribly deforms the picture. The only way out of this is to select 4:3 manually and once you do that it will not autoswitch to 16:9 even if the scart lead or the WSS signaling information is indicating that it should.
    This is a pity. Older Philips 16:9 sets did this OK.
    I also would have liked to have the option of automatic format change without picture deformation (so it uses only the 4:3 14:9 and 16:9 settings) but it is not available.
  4. nnicol
    nnicol
    Feb 4, 2005
    255
    5
    32
    +40
    Thanks Rob1698. That's what I thought. Yes the remote works but I was unsure if it should auto switch. Thanks for the replies.
  5. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    +9
    I tend to find myself just swapping backwards and forwards between 14:9 and 16:9. The 14:9 does a pretty sweet job of allowing you to watch those miserable 4:3 pictures whilst nearly filling the screen without distorting the image - only lose a little off the bottom and top...
    Jimmy
